File Request MS-16P11 MSI GE73VR 7RE
sware
SWARE
MS-16P11 rev 1.0
MSI GE73VR 7RE
Hello, i need working EC + BIOS dump on this motherboard, i use 3 different (2 from this page) and not working for me..
Hi
if all files are not working maybe problem is not related to bios
sware
SWARE
Hi
OK, give me other options, any voltage and da of power sequence is ok.. but only notebook not start, not short on cpu or any component, any component tested, new original EC (programed over KB conn writing, reading, compare ok), new bios chip writing on RT809H reading compare OK, all power seq is ok.. only problem with dump... give me other options...
send original bios and ec
sware
SWARE
original EC damaged (short) original bios damaged (short) not ussable..
In this notebook find 3 broken parts, EC (ENE KB9028Q), Bios (MXIC MX25L6473F), and charger ic (BQ24780S), any parts replaced, charging worked, discharging too but only 0,02Amps consupmtion, after power button only blink Caps and Power LED..
OK
i need original files to fix correct bios
you need datasheet for SY8288BRAC ?
sware
SWARE
This datasheet is SY8286A this is different chip, different pinout, different everything.. :( SY8288BRAC have pin13 FB SY8286A is 13 ILM :( not usable for me :/
there is no exact datasheet for that chip
i thought maybe that one is similar
